Hi
I installed the software logged in as an administrator on my PC (OS: XP Home), and everything's fine for that user.
However, when I log in as a non-admin user, there's nothing in the "Start" menu.
Any ideas?
Thanks
d.
Any ideas?
Thanks
d.
geposted Tue 06 Jun 06 @ 11:10 am
Locate VirtualDJ in Program Files > VirtualDj folder
You can always put shortcut into start menu or on your desktop.
geposted Tue 06 Jun 06 @ 11:16 am
OK, thanks - I'll try that later.
geposted Tue 06 Jun 06 @ 11:36 am
when you enter with a different user name on windows xp, some programs can't be shared so you won't see them, best regards.
geposted Wed 07 Jun 06 @ 2:53 am
Hi
there's a error popin up while i try to open i.e unable to locate DLL(dynamic link library).
geposted Wed 07 Jun 06 @ 11:19 am
If you install VDJ, you get a question like "Would you like to install this application for all users of this computer, or only for me". If you need to use VDJ running under different user account, select the first option. All registry entries, will be installed in the "hkey_local_machine" area. Otherwise it will installed in the "hkey_users" area.
You could also log on as admin and run VDJ from there
Ewout
Ewout
geposted Wed 07 Jun 06 @ 4:42 pm
