why when i use the equilizer crossfader my computer tends to freeze ....can u try to fix this problem...
my computer is
AMD 1000 Mghz ( 2x 4 x AGP )
750 SDRAM 133 MHZ
128 Mbyte Nviada VGA....
how can i solve this problem ( is it by putting on the reactivity option :slow ? medwim ? fast ?? )or u should update the VDJ software ??
thanx
my computer is
750 SDRAM 133 MHZ
thanx
geposted Tue 06 Jun 06 @ 11:19 pm
i think 1ghz is to less and use ddr ram but check maybe cheaps rams can be demaged or not to fast for Virtual dj
geposted Wed 07 Jun 06 @ 4:25 pm
"The use of equilizer crossfader the first time tends to freeze" it's a bug know by VDJ team, the second time I don't have any problem if I move it, you can try...
geposted Thu 08 Jun 06 @ 10:59 am
