I tried to download this skin but it is only a file without extension. What do I have to do to use this? Thanks.
geposted Thu 08 Jun 06 @ 1:32 pm
Hi, This is a browser problem. You must be using Opera or Mozilla. Try with Internet explorer and you should be able to download the .exe. Just execute it anywhere and it will add the right files at the right place.
Regards.
Karlo.
Regards.
Karlo.
geposted Thu 08 Jun 06 @ 1:55 pm
I think maybe just renaming the file and putting a " .exe" after the filename will work...
Not sure... but if it doesnt work then just re-download it with IE xD
Dj Joe/Joaquin
Dj Joe/Joaquin
geposted Thu 08 Jun 06 @ 6:09 pm
Yeah that will work, looks like the mime types aren't configured on the server correctly.
geposted Thu 08 Jun 06 @ 6:13 pm
