HI just started useing Virtual dj and its great but i keep getting slow down and skipping some times? my computer is a p4 3GHz and has 512mb of ram will buying more ram taking me up to 1024mb sort this out?
thanks
thanks
geposted Mon 12 Jun 06 @ 10:11 am
as audio is decoded in the ram theoreticaly the more you have the better.
geposted Mon 12 Jun 06 @ 11:13 am
well.. ram is important. But you can also try to optimize your system. I have P4 with 1GB ram and it didn't work properly with 512MB, but with optimizing it was ok. Then i upgraded to 1GB.
Check my blog for optimizing guide (the long one, second one is for sound cards, but you can try it too)
geposted Mon 12 Jun 06 @ 4:27 pm
that is very true.
have a look at www.theorica.net
try Game xp , and safe xp to optimise ur settings if you are unsure of what to do , as even the smallest mistake in some of the more advanced settings on xp can make windows currupt.
both are 100% free and spyware and virus free
make sure you use the back up tool , in both programs.
hope this helps :)
aslo
,Xeon ur blog rocks !, il definatly give those ideas a try.
Thanks.
hope this helps :)
aslo
Thanks.
geposted Thu 15 Jun 06 @ 10:33 am
it just works for me :)
geposted Thu 15 Jun 06 @ 12:15 pm
