When I open the new TASCAM skins' zip file it consists of two files 1 x XML and 1 x BMP - When I view the BPM file it shows two layouts of the TASCAM deck. How do I call up the second of the two?
Thank you
PHIL
Thank you
PHIL
geposted Wed 16 Jun 04 @ 9:57 am
the second layout is just the active one.
If you want to use the tascam skin just put the ZIP files on the skin folder and select the skin on Virtualdj
geposted Wed 16 Jun 04 @ 10:09 am
Yes that is what I thought but it looks completley different, there are buttons that I have never seen before - try doenloading it and look to see what I mean.
geposted Wed 16 Jun 04 @ 10:34 am
The "second" deck-layout is a photography of the real TASCAM CD 302 DECK, with all the reals buttons at their true place.
When I make a skin based on a hardware, I always try to keap the very original aspect of the deck, but you know, it MUST be adapted to the VDJ use so there are the differences.
I still use this graphic to implement new features.
FRUiT94
FRUiT94
geposted Wed 16 Jun 04 @ 2:01 pm
