Hi
I have found that if I move my jog wheels VERY slowly forwards or backwards, VDJ is not affected by the command. It seems that VDJ only picks up the command if a minimum speed is achieved on the wheels. This is a real pain when you want to move the track a tiny bit back when it is stationary. I end up using the mouse on screen at times.
I used Midi-Ox to see how the midi commands are sent from the MK2, and they are instantaneous. Any movement at any speed of the jog wheels will send a midi command. How has VDJ interfaced into MK2 because it seems that the jog wheel response is not up to scratch (no pun intended) :)
Regards
Regards
geposted Fri 16 Jun 06 @ 12:42 pm
Hi,
I think jog wheel sensitivity is being worked at right now by DJCel with his ever so popular HDC mapper. I think you will have to wait for that -BUT- youll need a pro verion to use it.
Karlo.
Karlo.
geposted Fri 16 Jun 06 @ 12:56 pm
For DJC (1st version) there is already out v3.0 mapper and it includes settings for jogs sensitivity. For MK2 i don't know...
geposted Fri 16 Jun 06 @ 2:02 pm
All is possible adrianh but you are only "home" user and the mapper work only with the PRO version.
https://virtualdj.com/products/djcedition.html
You can consider the low price of the update of your VDJ version https://virtualdj.com/purchase/discount.html
Ps the mapper works perfect for any DJ console version (MK1, MK2 and MP3)
geposted Fri 16 Jun 06 @ 2:50 pm
Great news cioce ;)
geposted Fri 16 Jun 06 @ 4:13 pm
And really thanks to DJcel for the mapper ;-))
geposted Fri 16 Jun 06 @ 4:20 pm
