why cant i use pitch bend and pitchbend rest on my xp10 (as a set button)
geposted Mon 19 Jun 06 @ 2:08 am
please answer me, maybe if you all can fix the way the flanger sounds then mabe i wouldnt have to use the pitch bend/reset to get a real flanger sound
geposted Thu 22 Jun 06 @ 2:36 am
If there is possible to set in VDJ preverences (under XP10 settings) it should work. Otherwise you can't use it as button on xp10.
What is wrong with flanger sound anyway?
geposted Thu 22 Jun 06 @ 10:57 am
conpare it to the sound of a real flanger like on a real mixer look listen www.pioneerprodj.com/cm/products/mediafile/flanger.mp3 i could make a song sound like this with a pitch bend by two unless you could tell me how to make vdj's sound like this cause ive tried with all the flangers at all different settings
geposted Thu 22 Jun 06 @ 8:18 pm
VDJ really doesn't have flanger like on mixers yet. So you have to wait till next generation of flanger. I have external effector for that.
geposted Fri 23 Jun 06 @ 11:31 am
