Does anyone know if you can adjust the dac3 pitch controll to be less sensitive. It has way to wide of a range and dosent make for smooth pitch transition?
geposted Mon 19 Jun 06 @ 4:43 pm
This can be done inside the program.
Open config and general settings.
At the bottom change the pitch range % from 33 to 8%.
geposted Mon 19 Jun 06 @ 4:48 pm
