It seems to be a great plugin.
However: It doesn't much matter that the plugin is launched on the deck 1 or 2 but after some seconds of use, instead of it stops, the first effect of the deck 1 engages until the crash.
Is there a solution ?
Clax
Clax
geposted Wed 16 Jun 04 @ 8:48 pm
I realised that this problem occurs only with VDJ v2... I'm working on a fix, (reprogramming it using the v2 sdk)... However, as you can see in this post:
http://www.virtualdj.com/forum/display.html?topic=5158
I can't seem to get a good quality sound... I hope that the dev staff (or someone who knows the solution) will answer soon so I can issue a fixed version...
This is sad because the plugin worked perfectly with v1.09
Cheers,
macourteau
Cheers,
macourteau
geposted Wed 16 Jun 04 @ 9:14 pm
I found this is a problem with all the v1.0x plugins that try to activate/stop a plugin in VDJ2... Maybe this will eventually be fixed, or if I can have a solution to my problem I'll have an updated version out as soon as possible...
macourteau
macourteau
geposted Thu 17 Jun 04 @ 1:42 am
Thanks in advance marcouteau. I really like youy effets.
geposted Thu 17 Jun 04 @ 4:36 am
The problem is now fixed. I updated the file -- just waiting for it to be reviewed before it's available to download... :)
macourteau
macourteau
geposted Thu 17 Jun 04 @ 11:59 pm
Allright I'm waiting
geposted Fri 18 Jun 04 @ 12:20 am
The update is now available in the effects section :)
macourteau
macourteau
geposted Fri 18 Jun 04 @ 3:06 am
Thanks I'll test it as soon as possible
geposted Fri 18 Jun 04 @ 7:02 am
Good job it works.
Go on.
Clax
Go on.
Clax
geposted Fri 18 Jun 04 @ 11:47 am
Marcouteau
I had an idea for a new plugin but I don't have time enough to learn how to do it.
I had written my algorithm but not in informatical language yet.
Can we associate to build it ?
If you're ready to do it with me I mail you.
Can you read french ?
Clax
Clax
geposted Fri 18 Jun 04 @ 11:50 am
The plugin crashed.
It was activated in a loop.
The loop has less beats than the number selected in the plugin before ending.
Clax
Clax
geposted Fri 18 Jun 04 @ 2:42 pm
Yes I can read french (it's my first language). You can email me to the address in my profile, or if you use MSN, you can add me to your list. I will be working away from home this summer, but I will be checking my emails and MSN often, so I can work on plugins during that time.
I would certainly like to help in making this new plugin. :D
Concerning the crash, I'll see about it... It's because the plugin uses the position where it was started in the song to calculate the fadeout... I'll test and see if I can fix it.
Regards, macourteau
Regards, macourteau
geposted Fri 18 Jun 04 @ 3:49 pm
