I'm trying to stop the software from automixing. I'm evaluating the product to do 'social' parties and not any type of techno or house where i need to use BPM. I'd rather be able to load up the decks and start / xfade on my own... Especially if I want one to end and be 'dead air' until I'm rady to start the other deck. There has to be a simple way of doing this, but I'm missing it.
Can you advise?
Thanks in advance.
Can you advise?
Thanks in advance.
geposted Wed 21 Jun 06 @ 8:39 pm
You have to disabled auto mix possibly enabled by shortcut at keyboard. Check your shortcuts in VDJ preferences to find one which is for disable automix. You can also enable/disable automix using this button in skin (only in some skins):
You can also set Fade Lenght to minimum and crossfader will move very fast to another side when using automix.
geposted Wed 21 Jun 06 @ 10:02 pm
Thank you!!!! That was it. I knew it was easy. Just had to learn the place to look.
geposted Wed 21 Jun 06 @ 11:24 pm
You are welcome :)
Anyway.. do you still using Trial?
geposted Thu 22 Jun 06 @ 12:04 am
