Forum: Old versions
Topic: virtual problam
how can i make virtual dj smaller in my screen 800x600 because otherwise I can notsee the hole program in screen. for some reason windows will not let be change resolution. is there a command that will be change the setings in virtual dj
geposted Fri 23 Jun 06 @ 8:28 pm
A couple things...
First, verify what type of video card that you have and then visit the manufacturer's website to download an updated driver. Most modern cards can do far more than 800 X 600.
Second, if that doesn't work, download a 800 X 600 skin from https://virtualdj.com/addons/skins.html
This should fix your problem.
Mat
make sure u have the latest drivers for your video card ..maybe thats why windows won't let u change the resolutuion ..also if u have a second monitor active make sure its also 800 x 600 or over. alot of times if the 2nd display is active and is less than 800 x 600 it won't let the primary screen resolution change by alot depending if it's on clone or dual display.
I have the skin just that when a run virtual dj i need to go to rge right top to change it but because its large I cant. is there a command key that will open so I can do the changes of skin?
can u move the skin so u can see the config? ..try renaming the 800x 600 skin to default and replacing the existing one with it
Or you can remove the skin from the "C:\programfiles\virtualdj\skins" folder and next time you open VDJ, it's gonna open with your default skin. It's happened to me before n that solved it. You can always replace it later.
i think he is using the default skin 3.4 only has a 1024 x 768
Oh I thought it was a different skin, cause earlier he was trying to download skins.
widows will not let me change the resolution
can u post your computer specs/ video card
