I just bought and installed pro,and suddenly my samples don't work. They appear to be playing, but I get no sound off of them. The decks are fine, but nothing on the samples. Any ideas?
geposted Sat 24 Jun 06 @ 6:26 am
HI HAVE YOU CHECK THE GAIN FADER OF THE SAMPLE YOU WANT TO PLAY?
IF THAT DOESNT WORK TRY TO CHECK IF THE SAMPLE THA YOU RECORD HAS BEEN RECORD TOO LOW...
GOOD LUCK... DJ ANGEL(PANTERA LUZ Y SONIDO)
geposted Sat 24 Jun 06 @ 8:50 am
Next time you post in CAPS you'll be banned, we've already warmed you.
geposted Sat 24 Jun 06 @ 9:47 am
1. Check the volume of the sample
2. Check sound cards configueation. If you are using Advanced config, you have to select the channel fot samples too.
geposted Sat 24 Jun 06 @ 10:14 am
It was the channels for samples...thanks.
Now if I could just find the id3 title/artist parser.
geposted Sat 24 Jun 06 @ 6:15 pm
