Hi i am just posting this because i really want to get some turntables to use with my virtual dj programm but i cant afford the expensive ones and i have found a turntable that plugs into your usb ... www.mixman.com i was wondering if this is compatible with virtual dj if not can you tell me a site that i can purchase turntables for cheap , i need one that u use music off the hard drive or cds not viynals .
Please note i am only 14 so i cant afford big fancy ones or the viynals
And if possible can you help me out on my other posts...
geposted Sun 25 Jun 06 @ 4:59 am
add me to ur msn for a solution , u will need the full registered copy of vdj to use it .
msn- djdebange@skyfxlmedia.com
geposted Mon 26 Jun 06 @ 11:04 pm
