hey.
my internal database of virtual dj 3.0 has an error. you can deinstall the software and install it again but the error exists...!
can somebody helps me??
thanks
timo
thanks
timo
geposted Mon 26 Jun 06 @ 7:33 pm
you database got corrupted somehow if u know about xml you can look for the error yourself but if you dont mind losing ur bpm's and cues just go into the virtualdj folder and delete database.xml (while VDj is off)
geposted Mon 26 Jun 06 @ 7:37 pm
hey... thanks for your tip.
it works..
it works..
geposted Mon 26 Jun 06 @ 8:58 pm
no problem glad i could have helped
geposted Mon 26 Jun 06 @ 9:46 pm
