Topic: How to load a song
Is there a command so I can load a song from a key stroke? I am used to pcdj with using the number one key on the num pad to load player 1 etc
geposted Thu 17 Jun 04 @ 11:44 pm
that would actually be pretty cool keyboard shortcuts...
Don't know if its possible, maybe someone else can tell you.
But if not, hope to see that possibility in future versions...
Load song to desk 1 with number 1, and 2 with number 2.. cool!
anyway, great to see you have converted to VDJ :)
dj in norway
geposted Fri 18 Jun 04 @ 1:24 am
I been using pcdj for almost 3 years now so I can manipulate it by the key totally. I have almost completed configuring vdj to the same key strokes.
F1,F2,F3,F4 are stop,play,rr,and ff on deck one
F5,F6,F7,F8 are deck two and so on
geposted Fri 18 Jun 04 @ 9:26 am
mp3jrickPRO InfinityHonorary MemberMember since 2003
Sowndman...............same one as Club PO?
We should be seeing mapping soon that would let the DAC 2 controller do everything for VDJ that it does for PCDJ.
If you have one you know what I mean as far as control goes, it's the only way to fly these programs.
geposted Fri 18 Jun 04 @ 10:49 am
"F1,F2,F3,F4 are stop,play,rr,and ff on deck one
F5,F6,F7,F8 are deck two and so on...."
don't have a DAC, so I really like the idea about a load track shortcut...
Play, stop, cue etc are possible to make now. Deck spesific...
But I guess u know that Sowndman?
I have lots of keyboard-shortcuts made for me... Play, stop, pause, loops (2-4-8) etc...
When u learn them by heart, you can mix and fix very fast :)
dj in norway
geposted Fri 18 Jun 04 @ 2:15 pm
