Hi
I have sound blaster AUDIGY2 NX conected on my laptop (Pentium M 1.5, 512 MB ram, INTEL CHIP SET, USB 2.0 SUPPORT) and i can't connect it to USB 2.0. The computer always recognize it as USB 1.1... WHY??? I downloaded lastest drivers for my intel chipset from DELL site and reinstall drivers. But it still not work. When i try to play audio DVD i hear cracking noise. This is because USB 1.1 does not support speed more than 12MB. But all other functions work good. I can listen sound on 2 speakers on sampling rate 96kHZ and 24 bit depth, on 4 speakers and surround 5.1 48kHZ with 24 bits and 7.1 on 48 kHZ and 16 bith depth Please help me what can i do??
Thank you in advance.
geposted Fri 18 Jun 04 @ 2:39 pm
I have the same problem :(
USB 2.0 ports work in USB 1 speed....
You can read the post here, to see if any of the suggested solution works for you:
https://virtualdj.com/forum/display.html?topic=5041
geposted Fri 18 Jun 04 @ 3:22 pm
you could also go here:
www.usbman.com
Many fixes, updates and suggestions for usb problems..
www.usbman.com
geposted Fri 18 Jun 04 @ 3:29 pm
thanks for the link... :)
geposted Sun 27 Jun 04 @ 4:45 pm
