Hi,
Do you know if it's possible to load a song in a X deck using explorer?
It should be like: left click of a song in explorer, then, SendTO: Virtualdj deck A or
SendTO: Virtualdj deck B.
Thanks
DjKad
Thanks
DjKad
geposted Sun 02 Jul 06 @ 1:48 pm
This is not possible yet, but as i know you can drag it from explorer.
You have great search function in VDJ why you need to use explorer? v4 will have even search function by title and artist it is told.
geposted Sun 02 Jul 06 @ 3:18 pm
Drag'n'drop from explorer is possible
geposted Sun 02 Jul 06 @ 10:25 pm
You can always drag a song, alt+tab into virtualdj and drop it that way.
geposted Sun 02 Jul 06 @ 10:27 pm
i need these shortcut cause i use laptop with external monitor with "multiple desktop function". I wish to put my laptop in the floor like a recordcase for choose songs and use the ext monitor only for show waveform and some track info . Target is to use a custom lcd display like 17'' but with vertical size of 5 inches. Sections of virtualdj should be "Floated" so i could use the browser section in one desktop and the waveform graph in lcd display.
geposted Mon 03 Jul 06 @ 4:07 pm
