i been having problems after i reinstall my software it was working good but i resintall my windows now doesn't want to work right because every time i want to play a video send me error invalid version of directx and i reinstall the software but doesn't work keep send me error
geposted Mon 03 Jul 06 @ 6:20 am
Download lastest version of DirectX and lastest drivers of your graphic card and it should work like before.
geposted Mon 03 Jul 06 @ 10:07 am
And make sure you have the proper codecs installed to play your video format.
Ewout
Ewout
geposted Mon 03 Jul 06 @ 8:55 pm
Start > Run...
Enter "dxdiag" and press enter
Check on the window that pops up that your version matches the latest @
http://www.microsoft.com/windows/directx/default.mspx
Once that's done, ensure you have installed any codecs as Superstorm above noted. This is what is most likely causing your problem.
geposted Tue 04 Jul 06 @ 12:49 am
