hi
i have got a problem. When i put my hercules dj console mk2 to use with virtual dj it dosen't work, all the lights just stay on and even when i tap on play button it dosen't do anying. But when i use the mouse it works properly. Some times it works with the hercules but it stops working. please help
alex montague
alex montague
geposted Mon 03 Jul 06 @ 6:26 pm
Do you have installed Hercules drivers?
geposted Wed 05 Jul 06 @ 12:06 am
Yeah i installed all of them and updated it as well
geposted Sun 09 Jul 06 @ 10:51 am
think your firmware/driver update might have failed
Try reinstalling it... and follow the on screen manual
geposted Sun 09 Jul 06 @ 3:23 pm
hi, i' ve the same f***ing problem... did you find the solution ??
daniel
daniel
geposted Thu 21 Sep 06 @ 12:32 pm
If you have the same hercules you must introduce your serial number in your profile
geposted Thu 21 Sep 06 @ 12:42 pm
yes or ul be ignored
such are the rules of this forum
geposted Thu 21 Sep 06 @ 2:14 pm
