I've posted this before, but it's practically impossible to find my previous posts. Anyway, I am having trouble using samples when I run VDJ on my laptop with my maya44/usb/dac-2/external mixer setup. When I run VDJ using just my laptop, the samples work just fine. My laptop is 1.8 ghz/768mb ram/ext hd/winxp home. Is there a setting I should be looking into so that VDJ can work with my "dj setup?" Thanks.
geposted Tue 04 Jul 06 @ 6:59 am
1. Does everything else play through this sound card?
2. What is the sound card setting in VDJ?
geposted Tue 04 Jul 06 @ 7:50 am
1. Yes. Everything else plays. The only thing that doesn't play is the samples.
2. Which settings are you referring to exactly?
geposted Tue 04 Jul 06 @ 8:22 am
In VDJ, config, sound card. What is the setting?
geposted Tue 04 Jul 06 @ 8:29 am
If you are using Advanced sound card settings, there you have to select channel for samples too.
geposted Tue 04 Jul 06 @ 10:13 am
OK, thanks Xeon. That seemed to do the trick, although I'll have to play with the settings in order to get each sample to play on both channels. Thanks to all who replied!
geposted Thu 06 Jul 06 @ 1:33 am
