I have the virtual dj software w/dj consule and I am installing the vdj program on a new computer and transfering all of my music to an external hard drive. I want to keep the same configurations that I have set in vdj on my existing computer. so that I dont have to manually adjust song cues, bpms etc. Any suggestions.
geposted Thu 06 Jul 06 @ 6:46 pm
you have simply to copy your VirtualDJDatabase.XML in the new folder of virtual dj in the other pc.
in the .XML file vdj saves all the info about each track: artist, track, album, bpm, cues and other...
hope I help u!
bye
hope I help u!
bye
geposted Thu 06 Jul 06 @ 6:57 pm
Thanks that worked. Now what about copying my playlists so that they target the songs on my external hard drive that I have transferred all of my music to instead of targeting my hard drive from the PC that I transferred my music from. Any suggestions?
geposted Fri 07 Jul 06 @ 12:54 am
I *might* have a solution. For my rigs, I install OS and PCDJ on C:\ and MP3s on D:\.
That's how all my gig rigs are setup. That way, I rip/tag/etc on my MP3 server and just replicate to either ext hd and/or gig rig.
So this time I installed VDJ into the MP3 folder - so the XML & TXT only needs done once on my server - then can get replicated across my main rig and backup. It takes FOREVER to scan the 40k+ files I have.
I fig any playlists/short cuts keys/etc will be backed up this way to all systems. I'll just need to make sure of config settings.
Folderclone is what I use to keep things synced. I'll let ya know.
geposted Fri 07 Jul 06 @ 1:24 pm
