Is there an easy way to print playlists or save them as a text file? Can't seem to figure it, am I just being stupid.
geposted Mon 10 Jul 06 @ 12:27 pm
you can open it with notepad and print it. just right click it and select open with (and select notepad) a .m3u file is already a .txt file with information on where the mp3's are. so u can open it with notepad and print it with no problem. you might wanna use the "replace feature of notepad to delete the C:\...... line from the songs
geposted Mon 10 Jul 06 @ 5:17 pm
Cheers, thanks for that. It's just that on a DJ forum I'm a member of, we sometimes post our playlists and that makes it so much simpler.
geposted Mon 10 Jul 06 @ 6:34 pm
Or open the playlist within Winamp, then double click the "misc" button, and select the save as html option. This creates a numbered list in artist-title format as an html page. If you want, you could then cut & paste this list back into notepad as a txt file...
geposted Mon 10 Jul 06 @ 7:54 pm
that sounds like a good way too..i just don't use winamp
geposted Mon 10 Jul 06 @ 11:02 pm
