Todays Controllers for Virtual DJ and PCDJ have limited options such as one cue n no hot starts unlike cd mixers that in most cases Denon DN9000 come with 4 Cues and 4 Hot Starts. Need more control over what i can do with the music on the controller and not only in the spftware. Very powerful program i agree but the options with ALL of the controllers on the marker are limited. I find myself burning tracks to cd and using my Denon S5000 or DN9000 to get the right cue points. The only thing i really like is the TCV. Great Development
geposted Sat 15 Jul 06 @ 11:51 am
This isn't a VDJ limitation. VDJ supports up to 99 cue points (if I remember well), and you can both jump&play or jump&stop to them. If you register a Professional version copy of VDJ (codes are registered, so don't use a keygen, it's useless), you'll be able to build your own controller and map its keys, or remap existing controllers. So don't say things if you don't know how the full version works!
geposted Sat 15 Jul 06 @ 1:30 pm
If you have a DAC-3 and use my mapper, you can directly set and goto 4 different cue points as well as trigger beat loops of various lengths and manual loop in/out. It also has an option to use ALL of the 1-10 buttons on the controller for set/goto cue if you wish, allow 10 direct access cue points!
With my mapper, the DAC-3 allows you to goto/set cue, trigger loops of various lengths/manual loops, trigger samples 1-10, directly trigger FX #1-#3 and change parameters, browse files/folders with jogwheel and video mixing including automatic crossfade.
v2.0 will also allow you to remap any of the buttons to suit your own preferences.
However, the DAC-3 mapper will only work with the full professional version of VDJ. The trial and home editions do not have the ability to load the mapper DLL file.
geposted Sat 15 Jul 06 @ 7:06 pm
Vdj doesn't make any of the controllers. You can ask the hardware manufacturers
geposted Sun 16 Jul 06 @ 11:13 am
