Can you control either deck on screen with just one deck? I noticed on the Time Coded settings you can have input 1&2 set to activated deck, so does this mean it would be possible, for example, to start a track playing on deck A with your cd deck, then switch it over to control deck B?
geposted Sat 15 Jul 06 @ 1:58 pm
S'ok, have sussed it :)
geposted Sat 15 Jul 06 @ 4:34 pm
it possible yes;)
Some skins have timecode switch/activate buttons for each deck, or you can make a keyboard shortcut for the same function :)
geposted Sat 15 Jul 06 @ 6:27 pm
so, if I only own one turntable and switch decks, the song goes on playing even though I stop the turntable for search the next track on the other deck?
geposted Sat 15 Jul 06 @ 6:41 pm
yes ;)
geposted Sat 15 Jul 06 @ 7:42 pm
Trust me, this can be an extremely handy feature in some circumstances. For example, the CD decks where I'm playing tonight won't read my TCCDs, so I can set up my DZ on one side, the laptop on the other and play away.
geposted Sat 15 Jul 06 @ 8:41 pm
I played this way last sunday at the Beach bar i work this summer, because one of the cd decks has a problem with its buttons.
Not the easiest way, also i stopped the music by accident one time or two... but it works..
geposted Mon 17 Jul 06 @ 4:39 am
here's a shortcut you can use
Go into the VDJ shortcuts tab in the settings.
Create a new shortcut with the key of your choice (I'd say 2 but only 1 is necessary)
Now you will have to chose Turntable in the list then in the sub menu you'll chose Timecode Active
You can set this either to default Deck or have 2 shortcuts and have 1 control Deck A and the other control Deck B (IE: Z for Deck A and / for Deck B) the keys you use doesn't matter I use a midi controller and can do this with that as well. So now you can disable the timecode on 1 deck and only control 1. then just de-activate that deck and switch to the other one.
geposted Mon 17 Jul 06 @ 5:49 pm
thank you so much...I'll test it sudden.
some posts ago, someone said that there are many skin with the switch button to activate the timecode or in deck A or in deck B...which are these skins??
thanks
thanks
geposted Mon 17 Jul 06 @ 6:17 pm
Using these settings with tcvs on active desk is possible to use prelisten?
geposted Mon 17 Jul 06 @ 6:31 pm
Can you use 1 CD player to control VDJ but have 2 channels hooked up to the external mixer? How would this work and how would I hook it up?
geposted Fri 04 Aug 06 @ 7:50 pm
