Forum: Old versions
Topic: Problems on nVidia nForce2 chipset
mk303Home userMember since 2004
Hi!
I've just installed VirtualDJ 2.00 and switched to "4.1 soundcard mode" but it doesn't work. Decks A&B are using both the front and rear channel of the soundcards. I've set the soundcard to 4 speaker mode but the problem still remain.
I'm using:
ABit NF7-S v2.0 (nVidia nForce2 chipset (SoundStorm soundcard)
WindowsXP SP1
VirtualDJ 2.00
Any suggestions?
Thanks!
geposted Sun 20 Jun 04 @ 2:51 pm
mk303
If you buy VDJ 2.0 put your serial on your profil and you will have some help, if you use the demo version this feature is only on the full version.
geposted Sun 20 Jun 04 @ 3:03 pm
Marius ! Great to see you bought VDJ too :) welcome!! :)
mk303 probably bought it too, as there is no 2.0 demo out.. :)
Don't know your soundcard, but I'm pretty sure someone can help you soon... :) just wait and see
And Mk303, please update your profile... so that you status says "vdj user" :)
geposted Sun 20 Jun 04 @ 3:24 pm
Maybe he use a hacked version ??
geposted Sun 20 Jun 04 @ 4:17 pm
it's awefully quiet suddenly... ;)
geposted Mon 21 Jun 04 @ 9:40 am
