Well I think I followed the tutorial but it is not working.
I am trying to set up my Denon DN-S3500 to my Yamaha sound card. I'm not using a mixer so I am using the splitter RCA cables. The Red/White are hooked up to my turntable and the single hookup is in the Line In on my Yamaha sound card. I burned the TCCD and it is in the 3500. I click config, click the TCV at the bottom, I also installed the ASIO4All.
I then click the Config Timecode, the input says Chan1&2, but if I click around anywhere it says there's not enough channels, and the only input I can select is the Channel 1&2 activated decks. So right now it says silent, I hit play on my deck and I can hear sound but all it is is a constant whistle. It also no longer says silent, it just says the quality is 0%. So I adjust the gain, click software RIAA preamp invert stereo, and change the turntable to CD Player.
ALso, I clicked Autoconfig and it says there is no time coded vinyl signal found, and that I should play a TCV and ........
So, this is where I am at and I have no clue what to do.
Any help would be appreciated. Thanks...
Also I am on the demo version.
geposted Mon 17 Jul 06 @ 6:52 am
Well, first of all for using 2 tccds you need full version otherwise you'll be able to use only one deck for 5 minutes. On the other hand if you are using asio4all you have to select it in the first combo since your audio card has no native asio drivers, so then there are 2 fields "in & out" select on active desk within "in" and master output within "out", check with these settings, Manquin DJ.
geposted Mon 17 Jul 06 @ 6:59 pm
Well I am at work so I can't really change anything at the moment, but I am basically just trying this out and if it works to my liking then I would upgrade to the full version.
geposted Mon 17 Jul 06 @ 7:51 pm
Well so far that didnt work. I still can't get any sound. However I can see when I exit out and try to play a song, it is hooked up to the deck because if I scratch it shows me scratching on the Virtual DJ.
Could there possibly be something I need to set up with the ASIO4All?
geposted Tue 18 Jul 06 @ 2:12 am
Well I have the Input:Ch1&2 Activated Decks
Output: Ch1&2 Master
but all I get is that whistle still.
I tried messing with the ASIO4All and I couldn't get anything with that. Any help would definitely be appreciated.
I'm linking some screenshots
<a href="http://photobucket.com" target="_blank"><img src="http://i62.photobucket.com/albums/h102/Jeffpru20/Yup.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
geposted Tue 18 Jul 06 @ 2:45 am
That link didnt work
This one should though
geposted Tue 18 Jul 06 @ 2:46 am
Holy Cow you have a cracked version, we can't help you anymore.
geposted Tue 18 Jul 06 @ 9:09 am
All those problems are because of your illegal version get vdj pro and you'll get better results,Manquin DJ. https://virtualdj.com/purchase/
geposted Tue 18 Jul 06 @ 8:53 pm
