Hi! I have some microphone problems.. It just not working:(
the red lamp shows when I speak but no sound comes out...
it says in the istallationbook that I must enable the talkover option in the main tab of controlpanel but can´t find it..
happy for all help I can get... /kentich
geposted Mon 17 Jul 06 @ 12:43 pm
          well.. open MK2 preferences (controll pannel of MK2) and enable it.
    geposted Mon 17 Jul 06 @ 10:30 pm
          Same problem for me, MK2 mic input doesn't work decent!!!
    geposted Tue 18 Jul 06 @ 10:01 am
          This is strange. Does anybody has working mic with MK2??? :)))))))))) Device is made for support it, so it should work.
Anyway.. read my tutorial of microphones in my blog. There is many possibilities about non working mic. Maybe it is mic which is not correct for that imput at MK2.
geposted Tue 18 Jul 06 @ 10:03 am
          I use mkII and my mic input works fine, I find I need to seriously lower the output volumes of the virtual DJ decks to like half plus enable the "talkover Attenuation" to about -6db because otherwise the mic volume isn`t high enough to be heard clearly even on full volume of the mixer.
    geposted Wed 19 Jul 06 @ 12:30 pm
          Guys try to use mics made for computer. they are very cheap, but i think they should work perfect. So if computer mic works, you will probably need preamplifier for your mic. I have one from behringer, but i don't use it with DJC. It is cheap and it could help.
    geposted Thu 20 Jul 06 @ 1:10 pm
          Computer mics in my experiance don't always work on other devices, I once tried using a computer mic on a panasonic mx50 and it just didn't work, yet worked fine in the mic input of my PC;^]
    geposted Thu 20 Jul 06 @ 6:51 pm
          Like i said before.. there aren't all mics for all inputs. If you try with different microphones, you will find that some of them work and other not. But actually everyone work!
    geposted Thu 20 Jul 06 @ 6:56 pm
          Hi guys! ty for all anwers. but I cant find the mk2 preferences, I have´t any icon for my mk2 either?
maybe it becuse I get an error when I instaling my mk2 to the usb... It works fine with the VDJ do.
ty!/ kentich
ty!/ kentich
geposted Fri 21 Jul 06 @ 1:05 pm
