Has anyone been able to connect Audigy 2 ZS Pro to Virtual DJ (latest version) and use the Time Coded Vinyls? Can It be done in ASIO mode? As to send data from the turntables with the TCVs into the SB card inputs, then from the SB card outputs back to the physical mixer, and then from the physical mixer back again to SB card main input (just to name it so) or to an amplifier, either for multichannel upmixing for home using or high power end for a public event, respectively.
Any success? Any better ideas?
geposted Tue 18 Jul 06 @ 10:05 am
You don't need to write twice the same msg.
You can set it to work with TCV if it has at least 1 stereo input. With ASIO4ALL drivers it should work, But only with 1 vinyl with trial version.
geposted Tue 18 Jul 06 @ 10:20 am
yes, don't repeat posts I've already answered in the other post, regards.
https://virtualdj.com/forums/52621/General_Discussion/Audigy_2_ZS_Platinum_Pro_Help.html
https://virtualdj.com/purchase/
geposted Tue 18 Jul 06 @ 9:01 pm
@djmark028
Is only an advice cause using a craked version you will have lots of problems since those versions don't run well, and if I try to help you, you will have problems that I don't because of the version, best regards.
geposted Wed 19 Jul 06 @ 6:27 pm
