I want to get some feedback on a blend I made but I don't know how or where 2 upload my song.
geposted Fri 21 Jul 06 @ 5:15 pm
Hello!
Here you have biiiiig list of websites :)
https://virtualdj.com/forums/49743/Music_discussion/Don_t_know_where_to_upload_your_mixes_.html
What style of music do you mix?
geposted Fri 21 Jul 06 @ 7:49 pm
I got into Djing only last year so I mix mainly hip hop u know.
geposted Sat 22 Jul 06 @ 3:54 pm
I was thinkin of using "file factory" but do u have any suggestions?
geposted Sat 22 Jul 06 @ 4:17 pm
Totyo wrote :
mooload
File Size Limit: 500MB
Download Limit: Unlimited
File Life: 30 Days (Deleted only if there is no download activity in 30 days)
URL: http://www.mooload.com
in my opinion you can try using this one...
if your set is more than 500Mb, there are also others URL with that capacity.
so, we're just waiting to listen to your set!!
remember to buy virtualdj!!
see you
geposted Sun 23 Jul 06 @ 9:19 am
Mooload looked a little sketchy 2 me. It took too long to upload so I canced it all together. Have anywhere else I could go? I've seen alot of folks heere using "putfile", u think i should go 4 dat it's just the registration that has my foot on the brake pedal.
geposted Mon 24 Jul 06 @ 3:22 am
oh yea! I'm definetley buyin VDJ It's jus da dollar bills that's slowin me down, trust me I would've bought dis already if I had some money!
geposted Mon 24 Jul 06 @ 3:24 am
I answered your other post. I'll be happy to host your mix. Visit my site and contact me from there. www.djderricke.com
geposted Mon 24 Jul 06 @ 3:29 am
Where exactly do u want me 2 go on the site?
geposted Mon 24 Jul 06 @ 3:40 am
My email is on my site. I can't post it here. Click the contact button and email me.
geposted Mon 24 Jul 06 @ 3:42 am
Aight, I emailed u let me know if u got it
geposted Mon 24 Jul 06 @ 4:01 am
Here is DJ Shyine's remix of Jay-Z's Change Clothes. It's tight! Good work Shyine.
geposted Wed 26 Jul 06 @ 5:06 am
Hey! That mix was seriously ill :) but i have a question/s, i can get the acapella and the instrumental to beatmatch the bpms perfectly but the timing for me is alwayss off, like i would start the instrumental and wait for the downbeat then start the cued up acapella starting off it sounds ok but then it either gets too fast or too slow for the instrumental i always have trouble with the timing i even downloaded some other acapella mixes and i tried to make the exact same thing and still i get problems i align the CBG's and everything before mixing ??? hmmm any one have any tips on timing in the acapella mixes? cause that Change Clothes was absolutely hype and it goes so well
geposted Thu 03 Aug 06 @ 2:54 am
Ur using VDJ rite? Well if u r, beatmatching doesn't always work. I'm still new 2 dis so I'm not a BPM expert but I'll share my method wit chu. If beatlock doesn't work, I use my natural ability 2 manually beatmatch using trial n error. Whenever it's a lil off adjust it manually use the + n - signs 'til it's just right. I like to call it playin "catch up". In Change Clothes, I was doin dat through out the whole mix but only little by little so dat u didn't notice it, but it stayed on beat! Try it n tell me how it went. I'll have more mixes up soon 4 u to get an idea of what I mean.
geposted Thu 03 Aug 06 @ 11:11 pm
More remixes from Shyine have been posted on my site. Check em out:
http://www.djderricke.com/page2.html
geposted Sat 05 Aug 06 @ 3:35 pm
sounds good ;)
geposted Sat 05 Aug 06 @ 3:47 pm
Aight here's some other remixes I've made can b found herre:
Lend ears mi remixes!
They r under Guest DJs-DJ Shyine the list is thurr.
geposted Sat 05 Aug 06 @ 4:04 pm
My bad. Ignore dat last post. DJDE DIDN'T TELL ME HE ALREADY POSTED DA REMIXES!!!! Thanks anyway ;)
geposted Sat 05 Aug 06 @ 4:08 pm
Hey DJ Shyine thanks for the advice man, it worked ! :) I'll post my remix:
Jay-Z- Dirt Off Ya Shoulder Vs. Common Ft. Kanye West- Food:
http://www.mooload.com/new/file.php?file=files/060806/1154882643/Dirt+Off+Your+Shoulder+Vs.+Common+%28DJ+Sparkxxx+Remix%29.mp3
everyone plz tell me what you think :)
geposted Sun 06 Aug 06 @ 6:45 pm
Dat mix was hot, had me bopin' my head 2 da beat. Overall it went good 2gether. Jus a couple tips though. Try recogonizing the 4 beat in da instrumental 2 get it to match da acapella. Also work on fading da song out too jus a nice touch. Good job though.
I also have my own verison of Dirt off ya shoulder 2 let me know if u want 2 hear it.
geposted Tue 08 Aug 06 @ 2:45 pm
