I downloaded the trial version of Virtual Dj and when I ran the software a error popped up"Error in the ASIO sound driver"........any 1 know how to fix this error?--------------much love missa
geposted Sat 22 Jul 06 @ 8:03 pm
hello, if you plan to work with tcvs you should get a soundcard that supports asio drivers like esi U46DJ, on the other hand if you just want to check how the software work with mouse and keyboard, select the first option in audio card settings, also make sure you have the latest drivers of direct x which is required by vdj the last one is 9.0c,best wishes, Manquin DJ.
geposted Sat 22 Jul 06 @ 8:22 pm
Kinda strange while I thought that the Demo version of VDJ does not support for Asio.
What kind of sound card are you using? Do you have a sound card setup programme with your sound card? If yes (Soundblaster audigy), set it to normal WMA mode.
Ewout
Ewout
geposted Sun 23 Jul 06 @ 2:20 pm
