I want to buy a new laptop which has a widescreen resolution of 1280 x 800.
My favourite skin is the MIX station SV_04 VDJ 3.4 by serge6037:
Great look and functionality.
Does anyone with a 1280 x 800 screen resolution use that screen? How does it look? Does is work well? I really do not know how the usual resolutions look on wide screens and I'd like to hear your comments...
Cheers from Ireland
Cheers from Ireland
geposted Mon 24 Jul 06 @ 12:31 am
you can use it in 1024x768 "mode" on a widescreen...
I have 1280x800 too... And I can use all 1027x768 skins...
They dont fill the whole screen that way, but thats ok.
You can still make it fill the whole screen, by pressing maximize, but it will be a bit out of ratio then ("pressed" wide). But its not too bad ;)
But there are a few 1280x800 skins made, that looks better.. Think the Mixstation have a version like that.
Only issue with maximize skins that are too small, is that some experience black outs.
I've never had any. And very few do, but thats only in the full screen maximized mode.
geposted Mon 24 Jul 06 @ 12:37 am
Im sure the 1280 skins will start coming around more as widescreens start becoming more popular
geposted Mon 24 Jul 06 @ 12:44 am
Thanks for the information, lads. I hope we start getting some of these widescreen skins soon... :-)
geposted Mon 24 Jul 06 @ 1:06 am
i'll be making some as soon as i get a widescreen monitor
geposted Mon 24 Jul 06 @ 1:12 am
Visit to dj format blogs... there are any skin 1280
geposted Mon 24 Jul 06 @ 10:43 pm
I've tried to find dj fomat's blogs without any success. Can anyone provide the link?
geposted Tue 25 Jul 06 @ 1:26 am
Try to visit SKIN forum https://virtualdj.com/forums/13/Skins.html
This is the link of DJ FORMAT Blog https://virtualdj.com/blog/DJ%20FORMAT/
geposted Tue 25 Jul 06 @ 10:10 am
cheers, never noticed there was a skin forum!!! :-)
geposted Tue 25 Jul 06 @ 9:23 pm
You can find alot of help there
geposted Wed 26 Jul 06 @ 3:41 am
