In order to have the possibilety to make a pre-listening with the headphones when I'm mixing, what do I specifically need? - just a sound card with 4 or more audio ouputs? - perhaps another version of the software?
geposted Mon 24 Jul 06 @ 8:33 am
MK2 already has headphones out. You don't need any other sound card. If you have MK2 withoput sound card inside, you will need only 4.1 ound card. And pro version of software.
geposted Mon 24 Jul 06 @ 10:12 am
is the sound blaster x-fi platinum sound tarjet compatible for making the pre-listening while mixing a session?
geposted Tue 25 Jul 06 @ 10:06 am
You can use every 4.0 - 4.1 - 5-1 or 7.1 (X-Fi Platinum) sound card with the relative ASIO driver installed.
If you don't have asio driver try www.asio4all.com and connect your amplifier into the front output and the headphone in the rear output of the sound card.
The PRO version is not necessary for your setup and you can read here https://virtualdj.com/products/djcedition.html the DJ console edition limitation.
geposted Tue 25 Jul 06 @ 10:49 am
thanx a lot dude! it's been really helpfull :D
geposted Tue 25 Jul 06 @ 1:20 pm
i have problems with headphones and dj console if i connect the headphone in the specifical emplacement i can only listen what speakers diffuse
geposted Thu 27 Jul 06 @ 6:08 pm
You don't need asio drivers to use headphone prelistening so you won't need asio4all, it's easier to use the default wdm drivers anyway as they are designed for windows os and are a newer more stable format (in my experience), this is not to say that they are better, but just easier.
What you do need is Virtual DJ Professional, or a Hercules Mk2 console (do you have this? - it seems all Herc consoles use the Mk2 icon now..), but then you are limited to the console and your soundcard doesn't come into it.
geposted Thu 27 Jul 06 @ 6:15 pm
Hi there,
Im not too sure about technical stuff but I am using version 3.0.0.0 or something like that of virtual dj and want to be able to use headphones - i only have a stereo out, how do i use headphone? is it a stereo splitter i need? if so where could i get one?
or, could i use the hercules dj control mp3 that i was reading about on the site?
ive currently been using cds to dj but now i want to change to laptop- but not very up to date on technical side yet!
Thanks
Thanks
geposted Fri 04 Aug 06 @ 11:35 am
Stop using a cracked version
geposted Fri 04 Aug 06 @ 11:36 am
OK, I was given it by a friend i didnt realise it was a pirate
geposted Fri 04 Aug 06 @ 12:23 pm
