I am interested in purchasing your product but I need to know does it support ttusb turntables by numark and if aso does it support 2 at the same time? thanks. d.j. t.k.
geposted Wed 26 Jul 06 @ 1:12 am
here are the specs for the turntable:
ttUSB Turntable with USB Audio Interface
Featuring Plug and Play USB compatibility with both PC and Macintosh computers, the TTUSB turntable makes digitizing one’s vinyl record collection a breeze. Equipped with an adjustable anti-skating control for increased stereo balance, support for 33.33 and 45 RPM playback speeds, ± 10% adjustable pitch control, and a 1/8-inch stereo minijack input connector to facilitate the transfer of cassette tapes, Numark’s TTUSB is the perfect tool for digitally archiving one’s record collection. Combined with Audacity’s software (PC and Mac compatible) for removing clicks and other noises, the TTUSB is an easy-to-use, comprehensive solution to the challenge of transferring one’s record collection to a computer or portable music player.
> Download Product Overview
_ Anti-skating control for increased stereo balance
_ Support for both 33.33 and 45 RPM playback speeds
_ ± 10% adjustable pitch control
_ RCA line outputs
_ Plug and Play USB compatibility with both PC and Mac
_ Packaged with all necessary cables to interconnect with both a computer and stereo playback system
_ Ships with Audacity software (compatible with PC and Mac) for removing clicks, pops, and other undesirable characteristics of vinyl
_ Audacity supports high-speed recording, then returns music to original playback speed
_ Audacity software includes ability to export to WAV and MP3
_ RCA line outputs
geposted Wed 26 Jul 06 @ 1:16 am
well.. yes... but its not a controller in itself.
The usb connection from that turntable is simply there to trasfer vinyls to mp3.
So the usb part of it, is for digitalizing your vinyl collection
But it would work as a controller for VDJ with timecode vinyls on them, just like any turntable would :)
geposted Wed 26 Jul 06 @ 2:26 am
sweet thanks very much.One more ? though. what about response time and accuracy. is there any lag between the controller and the program.
geposted Wed 26 Jul 06 @ 5:22 pm
there will always be a latency, but with a good asio soundcard, its pretty close to zero latency...
Not noticable
such as the u46dj soundcard:)
Not noticable
geposted Wed 26 Jul 06 @ 5:31 pm
