Hi
When I project VDJ onto the big screen TV I can't get the text function to work any help?
geposted Wed 26 Jul 06 @ 8:52 am
Have you tried to change the color of the text?
geposted Wed 26 Jul 06 @ 9:44 am
Yes still no good however when I take it off the screen it works fine
geposted Wed 26 Jul 06 @ 10:34 am
check your brightness and contrast some colors are affected if they are not set properly.
geposted Wed 26 Jul 06 @ 9:16 pm
My friend has this problem on his laptop. He can't use hardware acceleration as his video card doesn't support it - no video if he tries (however text works) - But with no hardware acceleration he doesn't get the text. HOWEVER, if he uses it in 'window' mode, and drags that across the TV screen it does work. Bizarre.
geposted Fri 28 Jul 06 @ 11:05 am
