When using timecode config what channels do the samples come out of ? Both I hope...
geposted Wed 26 Jul 06 @ 1:59 pm
I think that none :D
geposted Wed 26 Jul 06 @ 2:01 pm
You can choose that in advanced sound configuration
geposted Wed 26 Jul 06 @ 2:05 pm
View image here.
Regards.
Regards.
geposted Wed 26 Jul 06 @ 3:21 pm
Yeah.. 3 line outs and you can do it :D
geposted Wed 26 Jul 06 @ 4:10 pm
I have a maya44 - Only two stereo outs... :( was hoping the samples would come out of both of those as well.
Suppose I could use the laptops built in sound out for samples though.
geposted Fri 28 Jul 06 @ 11:09 am
Samples should work fine with Maya 44 - They do in my setup - Maya 44 + DAC-3 + TCV
They will play over the same channel(s) as the music if you do not have a separate output for them.
If you have sufficient output channels you can configure a separate output in the advanced soundcard config. The timecoded vinyls also has options in the output settings to choose a separate channel for sample output (If your ASIO sound card has 3 stereo outputs.)
geposted Sat 29 Jul 06 @ 3:01 am
