hello forum!
surfing the net, I just found this product of behringer co.: UCA202.
it's an usb audio interface 2in/2out that supports ASIO technology with ulta-low latency. just in your opinion, is UCA202 a good audio device for time-coded with virtualdj?
and, is it possible to connect ad the same time two UCA202 in the same pc and use both with vdj?
thanks for your answers!!
regards
regards
geposted Wed 26 Jul 06 @ 6:04 pm
it looks good, and should work good in theory ;)
but I havent tested it, and dont know if its as good as they say..
geposted Wed 26 Jul 06 @ 6:11 pm
ok, thanks dj-in-norway!
maybe, I'll buy and tested it also for you!!
geposted Thu 27 Jul 06 @ 9:34 am
Yes and no Joe, you can use two different sound card for output (amplifier & pre-listen) but you can use only one sound card with two stereo inputs for two time code and not two different sound card, make attention to this point.
geposted Thu 27 Jul 06 @ 9:56 am
thanks cioce!
so, in this way, if I buy this U-Control, I can only connect one turntable/cd deck to use with timecoded, and, if I use the switch timecoded active, I can exploit this audio interface so good...
I'll do it!
I'll do it!
geposted Thu 27 Jul 06 @ 10:33 am
