To have some better plugins , could you use the first slider for wet/dry or sometimes called "effect volume" too.
It will be easier for customers with external controllers. For example, see the current flanger v2 of TexZK with a midi contoller.
geposted Thu 27 Jul 06 @ 9:23 pm
It's also possible to change the volume slider directly from the DJ Console with default mapper this way. Place the effect mode on "Fx", then press and keep pressed that triangle button and move the left jogwheel. This way you can control the first slider, which is, in fact, the effect volume. Place the most used slider in the second place, so by doing this with the right jogwheel you can directly control the primary parameter of the effect.
geposted Fri 28 Jul 06 @ 3:41 pm
Hi Dj Cel..
I used the mapper 3.0 ... in VDJ 3.4 all fine with my Djconsole Vers 1 .... but now in VDJ 4 when load say error in registry ...!
You can review this error.. in this plugins?
thanks..
dj.manuel.garcia@gmail.com
thanks..
geposted Thu 24 Aug 06 @ 9:07 pm
Corrected in the new version. I will release it soon
geposted Thu 24 Aug 06 @ 10:28 pm
Thank you Dj Cel .... I hope so ...!
geposted Fri 25 Aug 06 @ 12:21 am
done
geposted Fri 25 Aug 06 @ 12:22 am
