I have used Mixmeister to create BMPs, saved it into a txt file then used the import option from VDJ Database update. After the conversion it says: import done. Now what do I do?
Do I need to move or replace an files?
geposted Fri 28 Jul 06 @ 7:17 pm
NECESITO PLUGINS Y NO PUEDO DESCARGAR NINGUNA WEA
CONCHETUMARE SON ENTERO MARICONES UNO LES COMPRA UN PRODUCTO Y DESPUES QUIERE MEJORARLO Y NO PUEDE DESCARGARLOS
geposted Fri 28 Jul 06 @ 9:49 pm
Que tipo de plugins necesitas? No se de que hablas.
geposted Fri 28 Jul 06 @ 10:11 pm
You can read on this page:
We remind you that effect plugins are downloadable by full version users only
geposted Sat 29 Jul 06 @ 5:01 pm
