just found a bug when using loop_lenght.
As far as i can see this is because the program doesn't keep the Loop_lengh value in memory when the temporary loop is created.
- Start a loop
- Modify the loop lenght using a loop_lenght wheel, so that it is a non standard loop lenght
- Click on any Standard loop button that also has a 'temporary' command set to it. (usually a right click)
- As soon as you release this 'tempory' standard loop the program will crash to crashgard.
geposted Sun 30 Jul 06 @ 9:41 am
Yes i got the crashguard too with virtualdj v3.4
Thanks
Thanks
geposted Sun 30 Jul 06 @ 9:18 pm
good bug I'm crashing too !!!
geposted Tue 08 Aug 06 @ 1:25 am
