it says in the time coded vinyl instructions to ground both turntables to the computer frame, do i also have to ground my mixer? and stereo amp?
geposted Mon 31 Jul 06 @ 8:58 pm
is not neccesary, just atacch the ground of your turntables to gabinet and that's it.
geposted Tue 01 Aug 06 @ 1:05 am
where should i attach it on a laptop any suggestion?
geposted Tue 01 Aug 06 @ 3:36 am
im sure theres plenty of metal screws on the back of your laptop, anything thats metal is fine ..or ground it to the vga port screw just make urself a wire with a screw that can screw in to one of the threads (warning do not use a sheet rock screw or anything long enough to wind up inside the laptop case)
geposted Tue 01 Aug 06 @ 3:46 am
ok i figured i would try that just wanted to make sure tht the screws will contact metal inside the case and not just more plastic.
geposted Tue 01 Aug 06 @ 1:57 pm
you got it :)
geposted Tue 01 Aug 06 @ 7:09 pm
