I have VDJ which i have used mainly on my Computer... but now what i wanna do is to connect an external mixer to my pc to mix my mp3 or CD.
hardware
standard PC
Creative Audy External
http://www.creative.com/products/product.asp?category=1&subcategory=205&product=9103&nav=1
creative Audy 2 ZS internal
i just want to use one of them so which one will be the best to use
where i'm not sure how thing will work after is... after connecting the external mixer to the sound card to play my mp3 or cd, which console will i use ? the Virtual DJ console or the mixer ? to mix if anyone can help me out with detailed information so i can decide what to buy..based on my need
so to accomplish that can anyone recommend me a good not too expensive setup ?
thanks in advance
hardware
standard PC
thanks in advance
geposted Mon 31 Jul 06 @ 10:11 pm
i was planning to buy this mixer Numark DM1002MkII
geposted Mon 31 Jul 06 @ 10:13 pm
A mixer or a soundcard won't do you any good till u buy the full version of VDj first, the soundcard options in the demo dont let u config. anything. what is it you planning on using VDj for ? stand alone operation or with TCV, TCCD
geposted Mon 31 Jul 06 @ 10:50 pm
that i know.... i will buy the pro version
geposted Mon 31 Jul 06 @ 10:54 pm
