When I had my Microphone on my PC, I used mic boost, otherwise it was low. On the Mk2 can I do the same?
geposted Wed 02 Aug 06 @ 8:29 pm
Don't really know what preferences you have in MK2 control pannel, but i would solve this problem with cheap preamplifier for mic. You will get even better sound from it believe me ;)
geposted Wed 02 Aug 06 @ 9:13 pm
I am not so savy about audio technical devices. Could you explain to me what the preamplifier is? Is it just to boost sound? How does it basically work? and where can I get one?
geposted Wed 02 Aug 06 @ 9:21 pm
Well.. it basicly make mic signal stronger. You connect it between mixer (MK2 in your case) and microphone. It is cheap and small. I have one from Behringer and it works very very good. It uses vacuum tube to amplify the signal and you can get even better sound with it.
I have that one: http://www.thomann.de/thoiw2_behringer_t1953_tube_ultragain_prodinfo.html
But that is also enough good: http://www.thomann.de/thoiw2_behringer_mic100_tube_ultragain_micpreamp_prodinfo.html
If you are from EU you can buy it there. it is better than buy new mic ;)
geposted Wed 02 Aug 06 @ 9:28 pm
Got it! Thanks :-) I will go out searching for a cheap one.
€100 is a lot 4 me, just go the Pro version hehe.
geposted Wed 02 Aug 06 @ 9:39 pm
that one for 44 eur is great ;)
geposted Wed 02 Aug 06 @ 9:41 pm
