I wonder if you can put a drum and bass synthetysator on VDj... I got songs that theri finish it's not so good, and this can solve the problem. Or the crossfader between two songs will be much better :D
Ciao, Dani
Ciao, Dani
geposted Thu 03 Aug 06 @ 8:51 pm
u could do that by using a Vst plugin , to make synth and drum machine effects
such as those from cammel audio
if ur not sure how to do it
try these programs to make synth and drump clips then use them as samples
aslo remember that Vdj is a dj program not a production program lol:)
geposted Fri 04 Aug 06 @ 9:00 pm
I mean, how I can do, 2 song's bass sound each like others... if there could be a fundtion to copy the bass for the last song for the new one it will be great. Or if you can cut the voice from a song to make it extended it will be also great. I've tryied the isolator efect, but it doesn't satisfied me.
What is a VST plugin plsss, and how can I get one ????
geposted Sat 05 Aug 06 @ 8:53 am
What you would like to do is probably not possible. See other topics about voice removing.
What I do to make an intro or lead out longer is to use the loop function. Most songs start without voices, so you could simply set an 8 or 16 beat loop and could play it forever. The same could be done at the end of the song, or in the middle (instrumantal break).
Vst is a standardised plugin method used in recording software and VDJ. Amazing and very good plugins could be dowloaded or bought. Just search for vst in google, you will find dozens. Keep in mind that removing vocals totally will not work in most cases. You will need acapella or instrumental versions for that purpose.
Ewout
Ewout
geposted Sat 05 Aug 06 @ 4:28 pm
