Can anyone tell me how to create a shortcut that will 'activate' -  then 'deactivate' the 'Use jogwheels for scratching' function?
I would like to scratch occassionally but dont' want to have to go into the config window every time to do this.
Thanks in advance...
JK in Toronto
JK in Toronto
geposted Fri 04 Aug 06 @ 9:20 pm
          If I'am reading you right, you want to stop the ability to scratch on the jog wheels?>
Just find a skin that has that feature on it
geposted Fri 04 Aug 06 @ 10:44 pm
          Correct - I want to be able to turn on & off the ability to scratch using the jogwheels. Would love to set up a shortcut to do that...
    geposted Tue 08 Aug 06 @ 4:43 pm
          I may be missing something, but wouldn't it work that if you didnt want to scratch, that you not mouseover the turntable and use the jog wheel...then when you do want to scratch you mouseover the turntable and use the jogwheel?  Or is there something else you want the jogwheel to do when you mouseover the turntable when scratching is turned off?
    geposted Wed 09 Aug 06 @ 2:58 pm
