ok i use virtual dj 3...and i downloaded some new skins...and this one particular skin i applied but now i cannot find the button to go to the options menu and change it back to the default skin. I just wondered if there was any way of doing this with keyboard shortcuts or another method???
thanks
thanks
geposted Sat 05 Aug 06 @ 6:56 pm
You can go into the virtualDJ Program files/skins and delete the skin you donot like and it will restart with the default skin
geposted Sat 05 Aug 06 @ 7:36 pm
And then check preferences which shortcut you have set for VDJ preferences.
geposted Sat 05 Aug 06 @ 7:55 pm
