This is real funny.
Using Hercules DJ Console MP3 and VDJ special Version it isnt possible to work with because the headphone function only works during PRESSING the headphone button.
This is very senseless and my question is: Will this problem be solved very soon? Or is it a kind of force to spend more money to buy a so called professional version?
Sorry but i am not amused about the "feature". if there is no solution in a short while in sight i will switch back to another - more professional system. I hate throwing money through the window!
geposted Mon 07 Aug 06 @ 6:23 pm
It's not a problem but a limitation https://virtualdj.com/products/djcedition.html
If you buy the PRO version you can delete this limitation https://virtualdj.com/purchase/discount.html
You have received a FREE version of VDJ because you have bought only an Hardware.
geposted Tue 08 Aug 06 @ 9:06 am
when you go back to another,'more professional system, you're gonna spent alot more than 124 euro.
geposted Fri 11 Aug 06 @ 9:05 pm
