Forum: VirtualDJ Skins
Topic: Skin without bpm display
Can you make a skin without the waveform, bpm and pitch % "display for me. I'm just tryin to learn Djing without this helps.
Thank you.
geposted Tue 08 Aug 06 @ 6:45 am
Ah, it's for djmixstation 3 home.
thanks
you can delete it yourself in the skin you like.
open the xml with notepad and search for rhythm.
delete al the lines from rhythm to rhythm.
then search for %Pbpm and delete al the lines from textzone to textzone.
then search for %Ppitch and delete al the lines from textzone to textzone.
then you have no pitch / bpm and wave form.
good luck.
your gonna need the bpm , the demo doesnt let you use the headphones, pretty hard to blend without headphones
I have a cracked version (I'm not a pirat, i'm just learning).
Thank you very much
