Hi, I just recently bought VDJ time-coded vinyl, and I am trying it out with the VDJ demo before I buy. I am using a Maya 44 soundcard, with two Technics 1200's.
There are digital artifacts in the sound, and when I scratch, the scratching sounds absolutely awful, with TONS of terrible-sounding digital artifacts. One deck seems to be worse than the other, and it's not a cartridge problem, I've tried swapping.
I also have the DjDecks software, and both decks work perfectly in that software. I do like VDJ more though, and would love if I could get this to work.
I would really appreciate any help/tips.
Thanks!
Thanks!
geposted Tue 08 Aug 06 @ 10:01 am
          Hi,
First, check your sampling rate. It should be at 44.1. Then make sure that you grounded your turntables into your computer. You can do so by screwing your ground into a pc chassis screw. Now another thing is that the demo version wont support ASIO, be sure to be aware of that.
Tell me if the problem persists.
Karlo.
Karlo.
geposted Tue 08 Aug 06 @ 1:23 pm
          the demo version only support one tcv or tccd and for only 5 minutes make sure your line in isnt muted
    geposted Tue 08 Aug 06 @ 7:30 pm
The VirtualDJ 4 version fixes scratch sound ;)
Its available shortly ...
geposted Thu 10 Aug 06 @ 8:45 am
