Whats an alternative to using that soundcard if i plan on buying V DJ because i was looking for it, it seems its out of stock pretty much everywhere...
geposted Wed 09 Aug 06 @ 3:11 am
Hercule's Dj Console
If in the UK try this:
http://www.argos.co.uk/static/Product/partNumber/0660581.htm
geposted Wed 09 Aug 06 @ 3:45 am
that looks weird lol....i already have 2 technics 1200 turntables and a numark matrix 2 mixer, and im thinking about getting V DJ so i can use my mp3s and scratch using the vinyls...but i need an external soundcard.... would the Ego Systems U46DJ which also has 4 ins and outs like the maya 44 usb be good for me?
geposted Wed 09 Aug 06 @ 9:37 am
The best now I think is ESI U46 DJ @ 95€ http://www.thomann.de/thoiw8_esi_u46_dj_prodinfo.html
Other info: http://www.esi-pro.com/viewProduct.php?pid=60&page=1
geposted Wed 09 Aug 06 @ 12:16 pm
Exactly. The U46DJ IS the "new version" of the Maya44, and it is the recomended soundcard for VDJ. It has 2 more outputs than the maya44, and has also a front panel with mic inputs, plus a lot of very good features.
Dj Joe
Dj Joe
geposted Thu 10 Aug 06 @ 3:45 am
In fact you can use any ASIO compatible soundcard with 2 Stereo LINE INs and 2 Stereo Line Outs at least. You can use M-Audio Delta 44 (or better), Terratec Phase 26 or 88, even a simple Creative X-Fi Platinum if you wish.
Good Luck!
geposted Sat 12 Aug 06 @ 1:53 am
i am usin vdj with u46dj and i can not seem to get it working using the timecoded vinyl i can hear the whistling of the vinyl but the is no movement on the configuration screen as it is not picking up a signal from the turntable. I have a feeling that it has something to do with the asio however i have done exactly as the set up has told me to do. When i turn on my vdj the error message "error in asio driver" appears but it allows me to carry on its only when the configuration for the tcv is attempted in exact correlation with instructions that music will not play, the track will freeze and keep repeating the point at which it froze, the track is completly unresponsive to the tcv. Can somebody please help me and tell me where i am going wrong or at least give me a step by step guidance on the configuration in accordance with the u46dj as at the moment i am not very happy with the product
geposted Tue 15 Aug 06 @ 3:22 pm
You need to mute the two monitor outputs to stop the whistle.
geposted Wed 16 Aug 06 @ 6:38 am
Dont buy that item, its the mp3 only version and does not have the phono ins/preamps, you will NOT be able to use it with timecode
geposted Mon 21 Aug 06 @ 10:50 am
Hi,
I am currently using an Terratec phase 26 USB soundcard for virtual dj. I would like to set this up for Time code CD, and i seem to experience problems for doing this. I can connect 1 cd player without any problem, but not 2. My soundcard manual says that i must switch between modes (Front, rear, etc..) to use ALL the inputs or outputs.
There is 1 stereo line-in on the front, and one one the back. I can not use them simultaniously apparently.
Anyone experience with this kind of matter ? Or can i connect the whole thing in mono or someting to et all 2 cd players working ?
Greet,
Fred
Greet,
Fred
geposted Wed 23 Aug 06 @ 6:38 pm
