Hi all, I am hoping somebody can help me with my setup.  After a lot of troubleshooting, I now have 2 SBLive:Value cards installed in my machine running the Kx Drivers.  They are installed and working fine.  I can choose either one in the Kx Mixer.  I have the output from each Timecode source connected to a LineIn jack on its own SBLive.  The output from each SBLive (Front or Rear, I\'ve tried both configurations) are connected to a Line Channel on my External Mixer.  I\'m trying to use each soundcard as a separate Channel.  I cleared the DSP Config for both cards and started from scratch.  I started with Prolog, Epilog, and FXBus only.  I mapped the Ac97 L/R to ASIO 0/1 for the first SBLive.  Then, on the second SBLive I mapped AC97 L/R to ASIO 2/3.  I\'ve tried several differnt ways to map both SBLive from Epilog to the FXBus for Output, but I can only get the first SBLive to Output.  One other really strange thing is that If I choose KxASIO as the soundcard I can\'t get any Timecode signal using \"Left:ASIO 1/2 - Right:ASIO 2/3\" as Input and Output.  If I install ASIO4All and Enable both SBLive cards, I can get a perfect 100% Timecode signal on each channel, but the Output is still only 1 channel.  If someone could help me with the DSP and mixer setup using the SBLive Kx Drivers It would be greatly appreciated.  BTW, I have onboard Nvidia Soundstorm Audio that I will use for all other Audio.  The SBLive cards will only be used for ASIO Timecode purposes.  Thanks for your help.
    geposted Wed 09 Aug 06 @ 4:17 pm
          The problem is that you can't use  the 2 decks in asio mode if you don't have the pro version, demo only works with one deck and for 5 minutes.
manquin DJ.
    manquin DJ.
geposted Wed 09 Aug 06 @ 7:10 pm
          Hi, thanks for the quick response.  I do have the Pro version.  I didn't register it yet b/c I might try to return it if I can't get it to work.  I really hope I can get it to work though, b/c it seems like a sweet addition to my mixing.
    geposted Wed 09 Aug 06 @ 10:32 pm
          ok, then do  this, go to your profile and enter your serial number and you'll have full acces to everthing (blogs, plugins, etc), although for working with tcvs I would recommend you the audigy x-fi platinum, it has native asio drivers.
    geposted Thu 10 Aug 06 @ 12:58 am
It works just fine with one SBlive, so why use two?! Your excuse for being known as a 'no license user' is rather thin IMO.. sounds to me you're fishing to get a warez version going..
Register your pro copy and we'll be happy to help out..
geposted Thu 10 Aug 06 @ 7:43 pm
          I guess that his problems are because of the kx drivers besides his "pro version".
    geposted Thu 10 Aug 06 @ 7:51 pm
          Why not.. the kX drivers are way better then the native SB ones.. lower Latency, hell even sound better
    geposted Thu 10 Aug 06 @ 7:52 pm
          well one time I had lots of problems with those drivers and my soundblaster live, but when I installed asio4all it all went fine.
    geposted Thu 10 Aug 06 @ 7:54 pm
I also have a lot of problem with KX drivers, and use ASIO4ALL, but after installing X-Fi Platinum (even Audigy 2 ZS Platinum) the sound was superb in every way. I don't use other drivers than which cames with my soundcard.
By the way Audigy 2 ZS Platinum will be fully compatible with the next version of VDJ.
Good Luck!
geposted Sat 12 Aug 06 @ 1:51 am
          I did figure out how to route the kx DSP so that I can get ASIO4All working.  1 channel per SBLive card.  I still can't get it to work without ASIO4All.  I'm trying to get the routing down so that I can have better latency using kxASIO only.
    geposted Sat 12 Aug 06 @ 2:53 pm
          you need to map manually in registry in order to tell vdj which channels are assigned for in and out.
    geposted Sun 13 Aug 06 @ 7:24 pm
          I do not understand the problem with kX you're having. After a clean install, without any other changes it presents a separate ASIO device for each available outputs (in stereo pairs). No need to fiddle with the DSP settings at all..
    geposted Sun 13 Aug 06 @ 9:30 pm
          There doesn't seem to be many options to choose from when selecting ASIO Channels.  Left 1/2 - Right 2/3,   Right 1/2 - Left 2/3,    and Activate Decks.  I have each SBLive (Line-In) mapped to ASIO 0/1 for the left deck and ASIO 2/3 for the right deck.  With this setup I can control the left deck, but not the right.  They're mapped using the ProFX in kx as well.  I use a Peak on each channel in the DSP to monitor the Timecode signal and It's perfect, but not Perfect in VDJ.  I have the Rear Outputs mapped to the FXBus.  FXBus 0/1 seems to work for the Left channel, but I can't get anything for the Right.  Any ideas what the heck I'm doing wrong?
    geposted Sun 13 Aug 06 @ 10:26 pm
          billymiller,
strange that you did managed to set it up that way, while advanced soundcard configuration is not available in the demo version?
The Demo version only support 1 master output. Time code is limited to 1 deck and only for 5 minutes.
Ewout
Ewout
geposted Sun 13 Aug 06 @ 11:13 pm
          I do have the Advanced Soundcard configuration under soundcard setup, but there isn't many options when I click on the Timecode Vinyl section and enter the ASIO Setup.
    geposted Sun 13 Aug 06 @ 11:45 pm
          Are you using a cracked version? If so we can't give you any help.
Ewout
    Ewout
geposted Mon 14 Aug 06 @ 12:09 am
          Indeed, the demo version does not support dual output anyway.
    geposted Mon 14 Aug 06 @ 12:47 am
          I have dual output, just not when using TCV.  I can't configure it properly.
    geposted Mon 14 Aug 06 @ 1:30 pm
          That's what I told you at the beginning of the post, demo version doesn't support 2 outputs
geposted Mon 14 Aug 06 @ 6:58 pm
You cannot have dual output on the demo version, please enter your serial# in your profile so we know you're not using a warez version..
geposted Tue 15 Aug 06 @ 1:28 am
